Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 Questions View all
Screen no image but not dark - new one needed?
I don't know how to post this with a photo of the screen but if there are any old timers out there who remember when TV stations we not on 24-hours a day that when they went off the air the screen was white background with random dots on it.
My daughters screen looks like that, seems to be functioning - you can call it and it rings, but no screen definition at all. Before I get out the heat gun and shell out a couple hundred bucks for a new screen I was hoping that if it were something else someone will chime in.
Thanks,
Duane
Add a comment
Most Helpful Answer
This may require a recalibration of the LCD/DIGITIZER connection. If you do plan to attempt this, be very careful about removing that screen. The whole front assembly is adhered to the midframe of this device. So, too much bending may cause parts to be damaged. A repair shop that is knowledgable about working on galaxy s5 phones will know this.
Im sure there is a guide to removing the screen without damaging it. I'll look for a link≥
Score 1
1 Comment:
Samsung Galaxy S5 Display Assembly Replacement
On step #7
You may use a hair blow dryer. Keep the heat on high and the speed low.
DO NOT USE A HEAT GUN.
That'll break $@$* usually.
Steps#8-#18
Guitar pick or credit card.
Best if you use something plastic unless you're use to repairing these.
And when you reach step #20, just reverse the process.
After you get it back together, heat it up again to let the original adhesive to re-adhere.
GOODLUCK BROSIF
by
Add a comment
Thanks! I've got both a heat gun and hair dryer so I appreciate the tip related to the heat gun as that is the first one I would have grabbed.
Duane
Add a comment
Add your answer
Duane Mawhorter will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 46
