Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
iPhone wont power up after it had no battery left
Hi everyone,
A costumer came to the store for a new charging dock, but i didn't disconnect the battery for this repair after i replaced the charging port the phone wont power on,
so i disconnect the battery and replug but still same result,
i tried a new battery in it and it works fine.
phone works perfect untill battery drains to 0% and the costumer cant charge it again then.. it gives the charging logo but it wont go to 1% or even start up.
but as long the battery don't drain lower then 1% everything works fine you can charge you can call you can do everything..
anny1 knows this issue?
thanks alot for reading this
greetz
Add a comment
1 Answer
Chosen Solution
The U2 ic chip needs replacing on the motherboard. It was either already damaged or leaving the battery in shorted it out. The chip controls charging. Always unplug the battery during any repair. I know these things rarely happen, but it's still a best practice to unplug the battery.
Score 1
2 Comments:
thanks ,
i just tried another battery and let it charge till 100% and the problem was gone lol
by
Good, so just a bad battery. In the future if you ever get one that wont charge at it all, its definitely the U2 ic chip.
by
Add a comment
Add your answer
Brian ifikske will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 77
