Syncing music to iPhone 6 with iTunes
iTunes is regarded as the most familiar way to sync music and other media files to iPhone 6. However, it is truly a challenging application for newbies as they may be impeded in dealing with the complicate functions. That’s why you need to read the guide below carefully in order to transfer music from PC to iPhone 6 successfully.
Connect your iPhone 6 to PC via matched USB cable.
Open iTunes. For the first connection, a window will pop out. Click “Continue” to allow iTunes to read your iPhone data. At the same time, another dialog will come out on your iPhone, on which you could tap “Trust” to continue.
After that, click the phone icon on the left corner of the interface. To manage your media files manually, you’d better go to “Options” under “Summary” tab, cancel “Automatically sync when this iPhone is connected” and check “Manually manage music and videos”. Don’t forget to click “Apply” when it’s done.
Import music into iTunes library from computer by clicking “File” and then “Add File to Library”. Once transferred successfully, you can select the music icon on top to see all the songs.
Now, click “Music” under “Settings” tab. Choose “Sync Music”. You can either sync entire music library or selected playlists as you like. Then click “Apply” button at the bottom.
2 Comments
Do you still have your old phone, and does it work?
by Brian Reeder
yes it works perfectly and it has all the songs on it.
by Sheila
