13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
Is it possible to use my MacBook just as a "tower"
I would like to setup my macbook to use just the system, keeping the lid closed, external monitor, wireless mouse/keyboard. Is this possible? Due to my lack of knowledge with Apple/Mac Specific cables, will the thunderbolt cable work with my macbook, to which i would go from thunderbolt to hdmi... Or is it not a thunderbolt but a different type of cable?
1 Comment
I suspect you really have a MacBook not a MacBook Pro here. Apple didn't make a Unibody MacBook Pro in 2008 only the MacBook.
Here is the full specs of your system: MacBook 2.4 GHz Core 2 Duo" (Unibody)
by
Add a comment
Chosen Solution
If it looks like a thunder port but is not it is probably a mini-display port. See this so you can tell the difference: http://www.cnet.com/news/confusing-mini-...
If that is the case you would need an adapter like this to get to HDMI: http://www.newegg.com/Product/Product.as...
Score 5
1 Comment:
thanks very much for the info
by
Add a comment
You have to get a thunderbolt to hdmi adapter. The connect the hdmi wire into an external monitor.
Score 1
3 Comments:
Ive read somewhere that thunderbolt wasnt used in the late 08 model macbook
is that true?
by
https://support.apple.com/en-us/HT204154
Scroll down to number 4 to see if your model is compatible
by
If this is a MacBook system it has a DisplayPort not Thunderbolt connecter (they both look alike). Note the symbol on it if it has a square with two lines it has a DisplayPort, if it has a lightning bolt it has a Thunderbolt port.
by
Add a comment
Add your answer
vgtalotta will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 407
