Agitator wearing out quickly
What would cause the dogs in the agitator wear out , rather quickly
How long is it lasting? Read the description of these replacement kits and see if one of them fits?
They lasted about two to three months. My wife also told me the main problem is that it would not spin on the med or heavy load settings . Thanks for the help
That helped isolate it:
Motor Coupling
The motor coupling connects the motor to the washer transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Thanks , after reading the links you sent I was thinking the same thing! I hope I get a chance to work on it tonight. I'll keep you posted. Thanks again
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 164
