Why is water leaking out of the hot water inlet?
I will explain by pointing out that the machine has 2 inlets - one for cold water and the other hot water. I have the cold water hose pipe fitted and not the hot water. When a cycle is started and water starts flowing through the cold water inlet at various points during this process a back flow of water through the hot water inlet is observed and hence by the ned of the wash cycle there is water in the floor.
1 Comment
Thank you so much for your speedy response. I have done exactly what you have advised and it's worked perfectly.
by Stephen Mulira
