Dryer not getting hot
How to fix dryer that isn't getting hot
Score 2
3 Comments
My stackable dryer will spin but not getting hot
by
Kamisia please start a new question and give us your make and model number
by
What would cause my dryer not to heat up and not cycle? The knob doesn't turn to shut it off automatically
by
Add a comment
Chosen Solution
Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer’s heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown out. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Score 2
Add a comment
My NEW stackable washer/Dryer lights just blinks and won’t start. When I press the start button it beeps three times. I’ve only had this unit for two months.
Add a comment
Add your answer
ctammee will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 38
All Time: 9,653
