Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
Why won't my computer restart?
I replaced the 256gb SSD in my macbook pro after cloning an image of it.
I set the cloned image onto a 1tb Samsung SSD. I have run it through disk utility and they system appears to be fine - it is just that the machine will only get 3/4 of the way through the boot process?
Running Yosemite.
Add a comment
1 Answer
Chosen Solution
Try starting first in Safe Mode by holding down the Shift key on startup. Since you cloned you probably don't have a repair partition, to check, hold down the option key on start up and see if it is there. If it's there boot from it and run Disk Utilities. Cloning was good years ago and a real time saver but not so today. Better to first format the drive then do an internet installation and use migration assistance to move your apps and data.
Score 5
1 Comment:
Thanks for this - ultimately, this is what I ended up doing. I have an image of my system and I will be making decent regular back ups in the future.
by
Add a comment
Add your answer
Gregory Machin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 153
