The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
496 Questions View all
Kenmore top load washer locks, then senses and then unlocks.Any ideas?
Kenmore 110 Series top load washer locks, then senses and then unlocks.Any ideas?
Add a comment
Chosen Solution
Cause 1
Door Lock Motor and Switch Assembly
The door lock secures the washer door shut during operation. Once the washer door is closed, the washer can begin operating. If the door lock is defective, the washer door will not latch properly. The door lock can fail either mechanically or electrically. Inspect the door lock for damage. If the door lock is damaged or does not latch properly, replace it. To determine if the door lock has failed electrically, use a multimeter to test each of the door lock switches for continuity. If one of the switches does not have continuity, replace the switch.
Cause 2
Door Lock
The door lock assembly might be defective. Inspect the door lock for damage. If the door lock is damaged, replace it.
Cause 3
Door Latch
The door latch assembly might be defective. Inspect the door latch for damage. If the door latch is damaged, replace it.
Score 2
Add a comment
It could be that the sensors are not working or they have become disconnected somehow and the machine doesn't think there is anything in it...
Add a comment
Add your answer
pefro826 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 7,840
