Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
water & dried worked fine charging sort-of but itunes doesnt regonize
i dropped my iphone 4s in the toilet quickly pulled it out padded it dry with towel put it in rice for two days then put it on charger worked perfectly fine for three days then just turned off no response my two different chargers wouldnt work the next day with a new charger plugged it into computer worked (only at the right angle) (also at first kept acting as if i was plugging in an taking out the charger very fast making the bell sound an lighting bolt blinking screen flashing) unplugged an plugged back in an was fine again itunes wouldnt reconize did i do perment damage can i fix ?
Add a comment
1 Answer
Chosen Solution
You need to clean the logic board with 90% isopropyl alcohol. Or higher. You'll likely need to replace the lighting dock
Heres a couple guides
iPhone 4S Teardown
iPhone 4S Dock Connector Replacement
Here's parts
iPhone 4S Dock Connector Image
Product
$19.99
iPhone 4S Image
Guide
iPhone 4S Teardown
Difficulty:
Moderate
Guide
Difficulty:
Moderate
25 minutes - 1 hour
Score 2
Add a comment
Add your answer
dominicf19 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 26
