Upper component cable not fits to logic board
Hi. First, sorry for my bad English.
I just disassembled my iPhone 5s and re-assembled.
Then I found volume up button is not working though I can't find any problem in its cable.
Volume down, volume control and power button which connected together in its cable works well, but only volume up button does not working.
Then I found that this cable isn't connected well to logic board so I tried to re-connect it but it didn't went as my expect.
It doesn't fits well and it is connected obliquely.
If I push the floated side of the connector to connect it, the connector comes out and I can't connect it well.
What would be the problem? Do I have to replace the entire cable?
2 Comments
i don't get it , you mean you can't put the volume button flex cable in the right place so the volume up button can't work? did the volume button flex cable even got broken?
by Kaye
I mean flex cable isn't in the right place, and I'm not sure that volume up button isn't working because of it. Flex cable didn't broken
by Alfred Woo
