install dual ssd and remove optical drive and hard drive
Hello,
it's time to make an upgrade for my mac.
I'm thinking to change optical drive and 2 tb hard drive (original purchase) with 2 ssd samsung evo 850 (the first for 1tb and the second for 500gb).
QUESTIONS:
1- can i change the 1tb ssd instead of 2 tb hard drive and change ssd 500gb instead of optical drive (installing an optical bay enclosure for ssd) ? and the put in external bay both hd 2tb and optical super drive?
2- need i the following parts?
b- iMac Intel 27" (Mid 2011) Dual Hard Drive Kit (as i already have: the Heavy-duty Suction Cups, 26 Piece Bit Driver Kit and Spudger....there is a kit only for: Custom SATA power & data cable and Custom-cut 3M mounting tape)
3- this guide is sufficient for my requirements?
Installing iMac Intel 27" EMC 2429 Dual Drive Kit (HDD or SSD)
4- this ssd is good for imac 27 mid 2011 ?
Samsung MZ-75E1T0B SSD 850 EVO, 1 TB, 2.5" SATA III Model no. MZ-75E1T0B/EU
Thanks to all for any suggestions,
Best,
Luca
4- need i other parts?
5- in any case any other suggestions?
Update (05/08/2016)
Hi Dan,
First of all, thanks for all your information.
Unfortunately, for budget limits I try to use this logic. Tell me if I can do it or not without risks:
1 - Make a full backup of whole HD (OS, apps & files) with time machine
2 - Prepare a USB key with El Capitan using a specific app from official file 'Install OS X El Capitan.app' about 6 GB
3 - Install in place of the optical drive the SSD (Samsung EVO 850 1 TB) using this bay Amazon - Adattatore HDD/SSD per Apple iMac 20" 21.5" 24" 27" (2009 - 2011) sostituisce SuperDrive + custody USB Slim (argento) per SuperDrive 12.7 mm (SATA - SATA) and putting superdrive into the external case.
2 - The old HD has not been touched. It still has the OS, files, apps and files for now. In any case I've used the wizard to export all photos and movies to the NAS and made a whole backup of photo database. Because I don't want to use anymore the photo app to manage photos and movies
3 - Power on and hold down Cmd A
4 - Install the OS and choose to recover only user accounts & apps
5 - After installed the new OS, if app and files are OK, format the old HD to get more space as secondary volume
In your opinion I should add or consider something else?
Product
Unibody Laptop Dual Drive
$24.99
Product
$27.99
3 Comments
In reply to your update: I think you have most of your bases covered here.
As to point #2 you'll need to use Disk Utility to delete the FAT32 partition and then create the GUID partition map and setup a Journaled partition. ITs best to download from the Apps Store the OS installer and use it to prep the USB thumb drive. After its setup copy over the installer to it as your emergency tool. You shouldn't need it if you follow the steps you've outlined.
by Dan
mmmm interesting...so you mean that after mapped the partition into ssd as journaled, i need only to copy the 'Install OS X El Capitan.app' file and then boot from ssd? or otherwise i've not understand how to install after made the journaled partition....mmmm as alternative solution: after partition, can i use for example a carbon copy software to move from hdd to ssd?....what do you suggesting for? Thanks
by luca
From the current bootable HD all you need to do is launch the OS installer app from the HD. You don't (nor can you install it) from the drive you want it install it on. In this case the SSD.
Think of it this way ... The shoe cobbler needs to put a new heel on your shoe. So you need to take it off for him to do it.
Its' the same here you need to be running from a different already bootable drive than the drive you want the OS installed on.
by Dan
