Cracked Screen and White Screen
Removal Guys Cracked my iMac screen and on boot up i can hear the boot up sound but just all white screen but goes away after leaving on for about 1-2 minutes and then works normally,but on restart back to white screen again. looking to know before i start replacement of screen is there anything else i should do to identify if i have another fault.
Any help would be gratefully appreciated.
Stephen
3 Comments
It would help to know why you took it in and what they did. Are they aware they cracked your screen?
by mayer
Resetting PRAM and NVRAM
1. Shut down the computer (by holding the power button).
2. Turn on the computer. Wait until I hear the boot sound.
3. Press and hold the Command-Option-P-R keys simultaneously.
4. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
5. Release the keys.
After doing this....
Reset the System Management Controller
1. Shut down the computer (well, it was already off)
2. Unplugged all cables from the computer, including the power cord and any display cables.
3. Waited at least fifteen seconds. I waited several minutes.
4. Plugged the power cord back in, making sure the power button was not being pressed at the time.
5. Reconnected my keyboard and mouse to the computer.
6. Pressed the power button to start up your computer.
If this does not help, the problem could be either a hard drive going bad or a bad ram module. Make sure all external drives are un-plugged.
by danny1310
You can also try this
Startup on single-user mode (cmd-s the turn on) the terminal will show up then type : fsck -fy , press return, type mount -uw, press return, type touch /private/var/db/ .AppleSetupDone, press return, type exit, press return.
by danny1310
