Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Question Closed
iPhone 5 water damaged dead, it heats a bit while in charge
I have an iPhone 5 that is totally dead after water damage, I changed screen, battery, charging port... Everything, so the problem is the mobo. It only heats a bit while in charge and that's all. Suggestions? Thanks to all.
11 Comments:
Did you clean the logic board with isopropyl alcohol? (Connectors, components, corrosion)
by
Yes, I forgot to mention. Thank you for your time
by
Mauro, we talked a little in that other thread. What percent of isopropyl alcohol did you use?
by
99% I hope I used the right one
by
Yeah, that should be fine. Kinda surprised. The next thing to do is micro solder the u2iC chip. Do able. However, you do need some equipment
by
Show 6 more comments
Add a comment
1 Answer
What I would do next is turn off phone....take a tupper ware bowl with lid...fill it half way to top.with rice ..put phone into bowl....let stay in there day or so...then try it....you should of did this as soon as it happened ...but if not ok....your battery maybe shot ..why want charge...do this then try to charge...goodluck
Score -2
4 Comments:
The phone was washed and dried, it has no water inside, it could have some corrosion, but with a good amount of luck I'll isolate the problem
by
josh rice does not do anything! It is absolutely useless and has no place in any repair.
by
Huh......No place in repair....whatever dude...it will dry any water or moisture in device that gets wet......you can take phone drop in sink full of water....if you take put straight in container with rice......by next day phone be good 2go.....rice does do something ....I've seen it two many times.....
by
For a long term successful repair you need to remove corrosive minerals left behind by water. Rice does not do this. Sure you may be able to throw the phone in rice for a few days and have it power on and work, especially with less severe water damaged phones. But in time the corrosion usually wins. So for the best chance of a successful repair clean all parts acceptable to corrosion as soon as possible with Isopropy alcohol or similar cleaning agent to remove corrosive conductive minerals left behind by water. Ultrasonic cleaner is the best choice if you have access to one. So for a successful repair it is just as important to remove corrosive minerals as much as it is to remove all moisture. So that is one reason why rice is not helpful in water damage repair, it in no way helps remove corrosive minerals where Isopropy alcohol does.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 169
