iPhone 5 water damaged dead, it heats a bit while in charge
I have an iPhone 5 that is totally dead after water damage, I changed screen, battery, charging port... Everything, so the problem is the mobo. It only heats a bit while in charge and that's all. Suggestions? Thanks to all.
Did you clean the logic board with isopropyl alcohol? (Connectors, components, corrosion)
by Ben
Yes, I forgot to mention. Thank you for your time
by Mauro Campo
Mauro, we talked a little in that other thread. What percent of isopropyl alcohol did you use?
by iMedic
99% I hope I used the right one
by Mauro Campo
Yeah, that should be fine. Kinda surprised. The next thing to do is micro solder the u2iC chip. Do able. However, you do need some equipment
by iMedic
Show 6 more comments
