15% Off Selected iFixit Tools — Limited Time
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Screen damage while changing the battery
Hi, LCD doesn't work correctly after replacing the battery.
When i was connecting the screen to the board something went wrong with the middle connector (out of 3). Probably i missed the correct place to put it and it began to burn. A little smoke appeared with the smell of burning plastic. Now i have white vertical lines and touch screen doesn't work in that area.
What can be the problem? Can i fix it by my own?
Thanks!
Score 1
1 Comment
If you screen is damaged, you can buy a new one to replace it, if you want to recover the lost data from damaged iPhone, I recommend you to use the iPhone Data Recovery tool, which enables you to restore your lost and deleted data in three simple steps.
Relevant: How to Recover Data from Broken Samsung Phone
by
Add a comment
1 Answer
Chosen Solution
You may have burned out the traces that lead to the connectors for the battery and/or screen (which is what that smoke was). You may want to try replacing the iPhone 6 Logic Board, then the iPhone 6 Used Screen. The logic board replacement is a difficult process, and your ability to fix it depends on how comfortable you are with repair.
Replace a logic board (motherboard) compatible with the iPhone 6. Fix processing issues like unexpected shutdowns, reboots or water damage. Image
Product
$83.99
Replace a scratched or cracked front glass panel or malfunctioning display, front-facing camera, or earpiece speaker for your iPhone. Image
Product
$40.99
Score 1
3 Comments:
I need to replace them both? It's not a problem with the screen and there is no opportunity to fix it in another way?
But still i don't understand how it could happen, the phone was switched off :(
by
Start with the logic board. To answer your second question, that's the problem with battery powered devices: they're always receiving power. If you plug the wrong thing into the wrong port and that port happens to be hot, then you could end up with a "hot" situation.
by
Thank you! Next time i'll bring my phone to service :)
by
Add a comment
Add your answer
Ic will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 1,975
