My LCD dont connect with my iPhone 5s
Hello, I have a problem with a purchase iPhone 5s LCD. When installing FLEX LCD, Screen and camera, the LCD does not connect flex With the main, pls help me :(
Sorry for my English.
@pabloguzman return it to the vendor and get a proper 5S replacement
It is the only way to solve it? @oldturkey03
I know that the digitizer is compatible but not the LCD so in the case of the assembly it appears you have somehow gotten a different one. Yes, I would return it to verify that you get the right one.
I think you've got a 5C lcd. The only difference between 5S and 5C display is the lcd connector.
Thanks , I think I 'll return .
The strange thing is that nobody had this happened . : / @kantura
Once it happened to me :) @pabloguzman
The frame holding the front display is different as well.
Right, but once i become a display with 5S frame but the lcd was 5c and i mean somezhimes it is a manufacturer failure.
@mustafa I haven't seen that before myself personally, must of been interesting for you when you saw it.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 156
9 Comments
@pabloguzman the connector does not fit? You phone is a 5S and you purchased the right assembly?
by oldturkey03
Yes, i bought the correct screen. Look this pictures @oldturkey03
https://drive.google.com/open?id=0By8Jxg...
Look the LCD flex :(.
by Pablo
The old LCD connectors have a square plastic washer around them. That's the only difference I can see in the photos. A clearer photo might help. If it is different, then there is little you can do. Contact the seller and tell them the problem. Possibly get a higher quality screen from IFixit.
by Josiah
Do you mean that the LCD cable connector doesn't fit on the logic board?
If that's the issue, are you sure you ordered the correct assembly?
by Arjan Kuiper
Hello @adriano33
Look at these photos flex LCD is different, and is the same: /
https://drive.google.com/folderview?id=0...
by Pablo
Show 4 more comments
