Why I can only access the google
i only can access google,youtube, and facebook . but i can't access another web. i have check my wi-fi and its work correctly, i think the problem is in my iMac
It sounds like you have parental control services enabled to limit the user (child) to safe sites.
This is a software setting in the User account that the Admin user set. You'll need to access the person who has the Admin account to correct it.
There are also other programs that could be used to also limit the user account and the network connection you are accessing (WiFi) could also limit you like in a school.
but i didn't set my parental control service. this is my wi-fi
Please explain? Parental control is a user setting when you create the user account. You could also have a third party app running on the system as well.
Bottom line here is your internet services are limited by the limits set within the OS, application, network router or even the network provider. This is not a hardware issue.
i had done what'd you say... and its still same... any idea ?
Try creating a bootable USB drive and then boot up under it.
i dont get it
No you're Mac is not the problem.
i have checked my wi-fi. its work correctly, i have tried to use another wi-fi but still same
If that is the true the issue is within your system. Again, you have parental controls enabled here either within the OS or an add on app.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 60
