Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1699 Questions View all
coils covered in ice
Coils in back of top freezer covered in ice. Freezer and fridge not cold enough. This happened two weeks ago. Hired repair man who said it was defrost board. I ordered
a new one from parts select. He said he could not guarantee the board. Now it is doing the same thing. The board worked fine for two weeks. What are the odds this board would stop working in this short period of time?
Score -1
Add a comment
1 Answer
Most Helpful Answer
There is a defrost heater in the freezer section that should cycle on and melt the frost that has accumulated. When the ice builds up as you describe the problem can be with the defrost timer, defrost element or defrost thermostat.
To determine the cause of the problem I'd suggest you remove the toe panel from the bottom of the refrigerator and locate the defrost timer. The timer will be mounted to a bracket so you may only see the round knob of the timer.
The round knob can be turned clockwise. A flat edge screwdriver can be used or a coin can be used to turn the round knob. Turn it slowly and at some point you will notice a click and the refrigerator will stop running. It is now in defrost. Give it a couple of minutes then open the freezer door and see if you hear any popping or sizzling as the heater melts the ice.
If you hear nothing then it is likely the defrost heater or thermostat is bad. I'd suggest replacing both to solve this problem.
If you hear a sizzle and popping noise then the heater is working.
After 20-30 minutes the defrost timer should advance out of defrost and start the refrigerator running again. If it doesn't then the likely problem is a bad defrost timer.
If you defrosted the coils and got the ice off of them, then they froze over again after replacing the defrost board, your next likely problem is low refrigerant. The same thing will happen on a home refrigerated air conditioner system.
Score 3
Add a comment
Add your answer
dg1948 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 80
