A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1700 Questions View all
Where is the power button "clicker" on a CUH-1200?
So I got a CUH-1200 PS4 today and the only problem with it is the power button doesn't work(eject button works fine). I took it apart and see where it goes( when I got it the power button was loose) but I don't see anything where the power button is suppose to hitting or clicking against. Can someone explain how this power button works or where is the part is at that the power button is suppose to click against?
2 Comments
@tronicsfix Do you have a video of replacing this piece? & do you sell replacement pieces for it?
by
@tronicsfix how much do you pay to replace the power button because i feel comfortable to dot it on my own
by
Add a comment
Chosen Solution
There is a part that it clicks against. There is a button that is soldered onto the motherboard that the push button pushes against. This button is what actually tells the console to turn on.
I hope this helps.
Score 6
23 Comments:
So am I missing it then? Cause I don't see anything there.
http://i1220.photobucket.com/albums/dd44...
by
Yes, you are just not seeing it. It's under the motherboard. If you shine a flashlight on the underside of the board right where the button slides in you will see it. I'll update my original answer with a pic of the button on the underside of the board.
by
Thanks,I wonder why it's not hitting it then? I guess I'll have to remove the motherboard and look
by
Update: It isn't there,previous owner must have removed it, nothing but a little ball solder left...
by
Thanks for the update...someone must have pushed a little too hard and broken it off. If that's the only problem with it it should be fixable.
by
Show 18 more comments
Add a comment
I have that same problem. The plastic thing that hits the contact on the mobo must be missing something, but i can not find out what it is - or where to buy a replacement. Do somebody know?
3 Comments:
I don't know of anywhere that you can buy it. You might keep your eye on Ebay.
by
You can buy it on Google it's 9.99
by
What is it called ? That plastic thing for 9.99 ?
by
Add a comment
Got to buy the whole board son!
Just use a paper clip and leave it alone!
2 Comments:
There's no way to turn it on with a paper clip with the power button missing. With the motherboard installed it would be impossible to get the paperclip back to the button.
by
Help me bro, I think you're the guy I been looking at for 2days, I think I bought that funny screwdriver for the ps4 from you too, those silver screws go where all the arrows are??? Or the little black ones??? How do you reinsert the power button???
by
Add a comment
Is it possible to buy a replacement for this? Mine doesnt click, seams stuck. Maybe bypass the clicker?
1 Comment:
what part of the power button is suppose to be clicking the part on the motherboard? I clueless...
by
Add a comment
this ps4 Power button switch, Easy to obtain replacement parts .egamephone have
Add a comment
Does anyone knows where the traces of powerbutton are cause mine powerbutton copper pads are ripped of and can’t find a schematic to see where the traces go
Add a comment
Add your answer
Travis Cox will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 85
All Time: 16,818
