The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
Question Closed
Camera split in half
I opened the camera application to take photo. The camera seemed that it had split in half and the right part was flashing green. I closed the application and reopened it and it seemed to work fine till today that the phone had the same issue
Add a comment
1 Answer
Chosen Solution
Most likely your camera has to be replaced. Is this the front or back camera?
You can buy the front and/or back camera from here, note that these are compatible with the SM-N9005 phone model.
[linked product missing or disabled: IF232-003]
[linked product missing or disabled: IF232-008]
Guide on how to replace the rear camera:
Samsung Galaxy Note 3 Rear Facing Camera Replacement
You can use the same guide to help replace the front camera. The front camera has a black metal plate behind it to hold it in place. You can easily lift the black metal plate up with some prying tool. The front camera should come out easily without much force.
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 200
