A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1700 Questions View all
Fan continuously speeding up after thermal paste and pad replacement.
Hi Everyone!
My PS4 after an hour or so would shut itself off to prevent damage. From what I could research online, I decided to replace the thermal paste and pads in the system, thinking that it might be bad seal on the pads or paste. (When I opened up the system for the first time, two of the pads were completely dried out.) After I replaced the paste and pads, I inserted a copy of Killzone: Shadow Fall to see if it would shut itself off again. When I started up the campaign, the fan ramped up to the highest setting. (It had started going through the different fan speeds from the menu, with Shadow Fall significantly speeding up the process.) I'm worried that I missed something, so I wanted to double check my work with you guys before I continued.
Here is what I did:
- Cleaned off stock thermal paste with Arctic Silver Remover & Cleanser.
- Replaced original thermal paste with Arctic Silver Alumina thermal paste
- Replaced stock thermal pads with Mod/smart Fujipoly 11 W/mk, 1mm thickness, 40% elongation. (Replacement pads were roughly 10mmx10mm. One thought I had was maybe the pads weren't thick enough to form a good connection.)
Did I miss anything? The thermal paste and pads was my best guess at the problem, keeping in mind the two dried-out thermal pads. Any help or input would be appreciated.
The PS4 is one of the early versions, that I believe is known for issues with the Thermal Paste.
Add a comment
1 Answer
Chosen Solution
Thermal paste does not and will not ever cause the console to just randomly turn off WITH THE EXCEPTION of an overheating event. Yours wasn't overheating unless it beeped loudly and turned the red light on before it turned off.
It sounds like the most likely cause of your original problem is just the typical problem with the solder joints/oxidized pads on the APU. This is a super common problem with PS4's.
As far as the problem you are having now it's most likely just something that didn't get put back correctly (Since the fan wasn't running loudly before you took it apart). I see this often at my shop. It's most likely either that the two large screws that hold the APU tight are not tight, the APU clamp is upside down or something is misaligned that is not letting the APU sit tightly against the heat sink. If I were you I would take it apart again and check everything closely.
I hope this helps and good luck!
Score 2
4 Comments:
Thanks TronicsFix! It was more the dried out thermal pads that prompted the replacement. I did what you suggested, and the PS4 still seems louder than it should be. When I went in, I was able to tighten one of the clamp screws a little bit more. I tested the system again with ShadowFall on disc & Kings Quest downloaded, and the auto shut off problem hasn't come back yet. If the original problem pops back up again, is there a way I can fix the solder joints/oxidized pads with the APU, or is it something I will need a reballer for?
by
You can add washers under the APU clamp and that will sometimes fix them. Sometimes for years, sometimes for months, sometimes it won't fix it at all. A reball would be a more permanent solution IF you can find someone who actually knows what they are doing.
Here's how the washer fix works: https://www.youtube.com/watch?v=pszuueUT...
by
Thanks man, you are perfect, my big brother will not disasseble me now.
by
The solder is not the actual problem. The issue is with the flip chip itself which would need to be replaced. There has been no evidence that the solder ever was the issue, on the 360, ps3, and every single electronics device to have ever existed. The transition to lead free solder started in the 90s, and if solder oxidizing was the issue, every console since the ps1 would have similar issues to the 360 and ps3.
by
Add a comment
Add your answer
Ben Eccles will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 17
All Time: 20,006
