Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Home button intermittently working
So this iPhone 5S I received in with a home button problem. The button is working intermittently, it is hit or miss, sometimes it will work for a full 2 minutes then it will be off for 5 sec then working again for 30 sec and then off for a minute, there is no pattern, just hit or miss. Touch ID is still functioning perfect. I have never seen this issue before.
******My question is, is there any way I can fix this homebutton so I can keep Touch ID? ******
I have other homebuttons I can replace it with and this does fix the homebutton issue, but as we all know you lose Touch ID function if you replace the homebutton.
What I have tried:
1Reconnecting Cable
2 Connected New home button fixes home function but obviously you lose Touch ID Anyways any help troubleshooting at all would be appreciated.
Score 1
Add a comment
Chosen Solution
Yes i have fix 5s home buttons that you can still keep the touch id. Great Question! I will post pictures really soon about this.
Update (03/30/2016)
Step 1:
Step 2:
Step 3:
Step 4:
Step5:
This applies to the 5s home button use the aftermarket to put it on the original one.
Score 2
4 Comments:
Thanks for the knowledge and detailed pictures I am going to try this tonight. I will keep you posted. Thanks again!
by
Ok so I replaced the dome and it is still working hit or miss, any other ideas?
by
UPDATE: Fixed! I misaligned the dome so it wasn't working correctly, I pulled apart realigned the dome and its working perfect. Thanks!
by
Great Glad To Help! Another tip This also works for power buttons and volume buttons!
by
Add a comment
so its actually the pressure contact which is at fault perhaps. when you look at the reverse of the home button you will see the metal springy pressure dome. you can remove this (its just kinda stuck on) and clean or i usually just replace the dome from a donor home button. probably best to remove from donor button first so you have grasp for how to remove without accidentally screwing up your original
Score 1
Add a comment
hi.. try cleaning the dome.. the one thats bouncing at the back of the home button
Add a comment
Add your answer
Mason McLaws will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 3,059
