Stopped before compleing last cycle
Why the washing machine doesn't complete it normal wash cycle at the rinse step?
Water Inlet Valve
During the rinse cycle, the water inlet valve opens to allow water to enter the wash tub. If the water inlet valve fails, the washer will continue waiting for the water to enter the washer, causing it to stop mid-cycle. To determine if the water inlet valve is defective, use a multimeter to test it for continuity. If the water inlet valve does not have continuity, replace it.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 216
3 Comments
A service man has diagnose the electronic timer. I changed for a new timer and calibrated it. The problem stills.
by Trahan
I Mayer. When the washing cycle stops, the light "rinse" steel on and the door unlocked. To continue, I have to push 2 times the button start to lock the door. Rinse start and complete. Do you think that the water inlet valve still affected the problem?
by Trahan
The water inlet valve is ok. Test continuity is ok. Problem still there. Is it related with the push button start???? After changed timer at 400$ CAN. and proceed at many washing tests, I am ready to give up. Desesperated Alou.
by Trahan
