Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Wifi greyed-out, bluetooth and date/time not working
Dear iFixit,
I do have some weird problems with my iPhone 6:
- wifi greyed-out (wifi antenne cable already replaced
- bluetooth keeps spinning/not working
- date/time is stuck (battery already replaced)
- rotate function not working
I hope someone has any clue on what this problem is and how this can be solved.
Kind regards,
Thijn Felix
Score 1
1 Comment:
I tried adding the apple glow feature and cut my power button/lighting assembly cable up, I am in the process of replacing that but my WiFi is also grayed out and blue tooth just spinning? Is this related
by
Add a comment
sounds like a hardware issue.
Wifi antenna Ic.
if its under warranty take it to App Store.
have you tried to upgrade software?
Add a comment
Try this take the board out and locate the murata wifi module iPhone 6 Teardown step 17 and grab a heat gun and heat up the wifi module for 20 seconds and put it back together and test.
Add a comment
I'm having identical issues. In Settings: General>About> Shows Wi-Fi Address is N/A. Bluetooth however does show a MAC address but when I access Bluetooth from main Settings Menu, it keeps showing the spinning wheel of doom.
I've seen numerous posts and videos stating that its the Wi-Fi module itself. Have seen some videos completely replacing the chip all-together, and others saying it can be from the soldering coming loose under the chip and to just heat the chip as @xterminal suggested.
Can you remove and replace the entire module by re-applying RMA-223 paste? Or do you have to solder the chip back onto the board?
Any suggestions, information, or advice would be greatly appreciated.
Thanks.
1 Comment:
Did you ever get this sorted? I have exactly the same problem.
by
Add a comment
Add your answer
thijnfelix will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 2,674
