Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Question Closed
no service , unresponsive touch screen
hi im at a loss here , first thing lcd was broken the phone was still working at this point , ordered a genuine apple screen to replace , went fine it was working , then my phone switched to no service , and wifi would turn off if i went in another room , so reset it , nothing , reset network setting still nothing , then i wiped the phone and reset and updated to ios 9.3 , then the problem , the screen has no response what so ever , and still no service , the phone is not blacklisted , do all these things go together or are they all different issues ,
Add a comment
try to soft reset it. (hold home button+sleep button at the same time until you see the apple logo)
If you changed the screen yourself, did you disconnect the battery while removing the screen?
1 Comment:
tried everything possible , bar smashing it up , its working now anyway , took the new one off , put the old one back on , the put the new one back on and it worked , still have no signal tho
by
Add a comment
Is there a possibility you could have snagged the antenna cables, located at the bottom of the phone?
With Regards
Alex
1 Comment:
i really dont think so , i never disconnected it or went near it , i will order a new one to be on the safe side thanks
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 139
