The third generation of the DJI Phantom series released in April 2015.
59 Questions View all
Remove the camera so I can flip it
Today my Phantom 3 Standard crashed on the ground. This resulted in the camera being vertically flipped (DJI logo is on top upside down). How do I get the camera off the gimbal, so I can turn the camera and put it back on?
1 Comment:
I have just done the same thing, really wanting to know how to restore the camera to its original position...any help?
by
Add a comment
I had the same problem and fixed it. I assume you've fixed yours by now. If not contact me at mikewade54@sbcglobal.net and I'll walk you through it
Add a comment
Hello I am having same issue can u help please
Add a comment
I had the same problem after a crash. The only way I could find to fix was to take a very small flat tip screwdriver and wedge it between the gimbal stop then gently slid it to its forward position. My camera is facing a couple degrees to the left but for me it's a bent gimbal arm that I'll replace at a later time.
I hope this helps and I'd be extremely gentle if you try this.
Add a comment
Add your answer
melvinerne1993 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 705
