The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
612 Questions View all
Is i9505 microUSB board compatible with i9506?
Hi, will board with microUSB port for Galaxy S4 GT-i9505 work in Galaxy S4 GT-i9506? Is this part the same?
Thank you for your answers
Add a comment
1 Answer
Chosen Solution
Pretty sure it will work fine. It won't work if you put say a i9500 charger port onto a i9505/6/7 phone.
However i9505 charger ports are used on 6/7 phones.
Score 3
Comments:
Thank you for your answer.
by
If you want more info, all the micro usb ports used on the Samsung Galaxy S4 variants are the same. It's the charger port assembly that is different due to how it's made with the antenna and etc.
by
@benjamen50 Does this mean that the logic board with USB port, mic... for i9505 will work in i9506? Thanks
by
Yep, the whole charger port assembly.
Their all labeled i9505 anyway on the charger port assemblies themselves for compatible models.
by
The i9505 charging port flex is not necessarily compatible with the i9506. For instance there is a high chance that the menu/back touch keys will not work properly. They may trigger on their own or not respond/light up at all.
by
Show 3 more comments
Add a comment
Add your answer
david8 will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 9
Past 30 Days: 41
All Time: 927
