Shop the Holiday Gift Guide
The Acer Aspire One 722 model #P1VE6 is a netbook that was released in July 2008.
Question Closed
while installing my windows 7
Setup was unable to create a system partition or locate an existing partition?
1 Comment
What caused you to reinstall windows? (What is the history of this laptop)
by
Add a comment
1 Answer
Most Helpful Answer
You can manually prepare your hard drive:
BIG NOTE: This formats your whole hard drive, don't do this if you haven't backed up your data!
Boot the Windows Installer.
at the first installer screen press shift + F10 to take you to command prompt where you can run diskpart commands
type: diskpart - press ente (to enter diskpart)
type: list disk - press enter (list all connected HDDs)
type: select disk 0 - press enter (assuming disk 0 is the desired disk)
type: clean all - press enter (which will erase entire disk including partitions)
type: create partition primary - press enter (which will make one new primary partition the size of the disk)
type: format fs=ntfs - press enter (which will format the partition with ntfs structure)
type: active - press enter (to mark partition active so boot files can be placed on it)
type: exit - press enter (exit diskpart)
type exit - press enter (exit command prompt)
Continue the Installation.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 233
