Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Searching... After water damage repair
I just finally brought my water damaged 6 back to life after tearing it down and cleaning everything with 91% isopropyl alcohol including soaking the board for a few hours scrubbing and blowing off with canned air every thing is working like new no problems except the carrier spot just says searching all the time now even if I put in a SIM card or take it out it never changes my question is what should I check I cleaned all the antennas is it just that the chip in the board is shot? Or is there another possible fix? I hate that you can't remove the emi shields anymore to really scrub all the chips
3 Comments
@jared91 this "can't remove the emi shields " concerns me a bit. You will have to remove all the shields to properly clean the board. Did you remove them?
by
Well how can I remove them they are soldered on to the board now I can solder but I don't have a hot air setup or anything decent to remove them
by
If you do not remove the shields, you are leaving 2/3 of the board uncleaned. Use a soldering iron (not a hot air station) to remove those. Even the cheapest soldering iron can be used for that.
by
Add a comment
1 Answer
Most Helpful Answer
Hi Jared,
Glad you could bring the phone back to life. Ive had the same experience with an iPhone 5C.
I would recommend that you try the following:
1. Remove the sim card
2. Go to Settings > General > Reset > Reset Network Settings
3 . Find a different known working and activated sim card and place it in the sim card tray
4. Turn on Airplane Mode, wait 30 seconds, then deactivate Airplane mode.
I would really appreciate hearing the end result.
Thank you,
Michael
Score 1
1 Comment:
I Tried it. But It dint Work. :(
by
Add a comment
Add your answer
Jared will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,128
