A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
213 Questions View all
Question Closed
Not draining or using fabric softener and displaying error code ld.
Not draining or using fabric softener and displaying error code ld. Can hear a little buzzing noise unplugged machine from electrical outlet and noise stops . try to change cycle won't make it any further. Drain hose is in proper elevated position. Thanks
Add a comment
1 Answer
Chosen Solution
Washer code Id - Washer is taking to long to drain water from the wash tub.
Is the drain hose kinked or clogged?
Is the drain hose installed properly?
Press POWER/CANCEL to clear the display.
Here' a video on replacing the drain hose: https://www.youtube.com/watch?v=f1MNlUfp...
Score 3
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,216
