Touch ID not working after opening the iPhone
Hello guys,
2 days ago I dropped my phone into the water. Well, nothing serious, only upper half got wet, but I decided to open the phone to let it dry, inside I found a really little bit of water and I had a bruise on the screen (now its small, so it will all dry I hope). So after 1 day I installed all back up (I took out battery, home button, front camera with speaker and rest attached to the plate under the LCD) and now the Touch ID doesn't want to work. Home button is fine, but i can't turn the ID function ON. My fingerprints also vanished. I did everything carefully and it's impossible that I damaged the cable from the sensor.
In the Touch ID settings I can turn it on, but then I get thismessage
What I can do to fix it? Any suggestions? I did a hard reset, network setting reset and all settings reset, one by one and unplugged it a few times (then i realised that I messed the orientation of this: http://imgur.com/2NCodsj but after replacing it I still can't get the Touch ID functionality)
Thanks in advance.
