Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Phone dies at 20%
I recently got a used iPhone 5s from my aunt. It is running iOS 9.2.1 and everything works fine exept for the fact that the phone will die with 27%, 25%, or 20%. When I plug it back in to charge the phone turns on again with the same battery percentage as it had when it died. Is this a software or calibration issue or do I need to replace the battery?
Add a comment
Chosen Solution
i had same issue with my 2 years old phone, at 30% it will totally shut down, what i did is i replaced the battery, now everything is perfect. i used the ifixit battery replacement kit
Score 1
Add a comment
I would try putting the phone in DFU mode and updating/restoring it.
Let the phone die and then charge to full
If it happens again the battery needs replacing
Add a comment
Usually happens when you don’t charge your phone often or the common one, the battery may be old or not working. You can charge it to full and kill it again over and over til it works.
Add a comment
Add your answer
Vince Parisi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 20
All Time: 5,761
