Phone unable to boot up nor into recovery mode
My GT-I9060I DS is unable to boot up completely and just hangs on the Samsung screen with a red exclamation mark in the top left hand corner. Also I am unable to boot it up into recover mode, it also hangs on the same screen mentioned above. It does however boot into Download mode but unfortunately there seems to be a problem with the usb drivers as Windows picks up device that reports and error, doesn't recognise the device despite installing and reinstalling all the drivers I could possibly find. Please help me recover my phone if there is a solution out there? Thank you
Score 1
1 Comment
did u find any solution???
by
Add a comment
Most Helpful Answer
Check the charger port for any blockage, is there any dust or blockage? If yes, use a tooth pick to clean it up. Then try download mode again.
Have you tried using samsung kies?
Score 3
1 Comment:
try spd flash tool and drivers might help http://spdflashtool.com/download/spd-fla...
by
Add a comment
Samsung Recoveryis a good program which can be used to recover deleted contacts, text message, photos ,muisc and videos from all kinds of Samsung device, including Galaxy S5, Samsung Note 5/4, Galaxy S7, Galaxy S6, Samsung Galaxy Note and so on.
Add a comment
same problem. I can not go in recovery mode
I can only go in download mode. with Odin always the result Fail :(
can not install TWRP, CWM, etc
my English is bad :(
solution with spdflash tool, I need stok rom in .PAC for GT-I9060I/DS......Samsung GT-I9060i Grand Neo Duos
I have only frimware in .TAR and .MD5
thanks for help
Add a comment
change the charger usb port in your phone only
Add a comment
Add your answer
Sebastian Fisher will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 2,391
