Repair guides and support for televisions manufactured by Panasonic.
TV screen won't turn on. Standby light solid red.
My Panasonic Viera plasma TV won't turn on. It won't respond to the tv remote. If you press the power button on the side of the tv the red standby light comes on solid but the screen doesn't turn on. No sound comes out either. After the red standby light comes on the buttons on the side of the tv don't do anything, including the power button.
Score 21
12 Comments
Now I just noticed that the solid light started blinking. It blinks 14 times and then stops for a second then blinks 14 times again.
by
I have a problem where the tv turns off it self after 1 minute when turned on and the red light blinks ? In that case what is to be done any solution please
by
My Cornea TV wont even turn on.If I turn it on the blue light flicks on and just for a while it changes to red meaning its switched off again.
please in need of urgent assistance.
by
My tv is onida co. , When won't turn on , tv not displaying picture & come to red light of standby mode , plz give the solution
by
The tv brand is nippon made in china 21 inches, the problems is the power is on then the led red color changes to color yellow then the monitor is black, how to solve?
by
Show 7 more comments
Add a comment
Chosen Solution
Here's a video on fixing the 14 blink code on the Panasonic plasma 50 inch TV:
https://www.youtube.com/watch?v=iHBIiRxh...
Score 13
5 Comments:
Great that works!
by
Fantastic I'm back in business cheers from clip
by
Don’t understand what do I press
by
Thank you so much Bugsy13! I thought I was going to have to get a new tv but your solution worked!
by
Telefunken tledd-32 does not power on what can it be
by
Add a comment
Most Helpful Answer
Turn tv off at the tv. Now keep your remote stand bye button held down. Whilst held down, press tv button on. Green light should come on. From bugsy13
Score 54
57 Comments:
I tried everything to solve our similar problem with our Panasonic Vieira TV and this is the one thing that finally worked. Thank you so much!
by
I'm a manager at a retirement apartment block. A 94 year old resident told me her tv wouldn't come on. I went through all of the fault finding in the book, but got no answer. I put the problem into google and your response came up. I went back to the tv and lo and behold it worked! Thanks so much for posting this solution.
by
Panasonic TX-P42U30B. Red light on and flashes with commands from remote but does not come on. This reset worked a treat. Now changes to flashing green and then starts. Many thanks, Have since found out
that set had suffered a power cut, so this could have caused the need for a reset
by
OMG it worked! A million thanks!
by
thx so much, this really helped
by
Show 52 more comments
Add a comment
Turn tv off at the tv. Now keep your remote stand bye button held down. Whilst held down, press tv button on. Green light should come on. I found this answer on the ‘Net’ and it worked a treat for my mother’s TV.
Score 2
Add a comment
Hold the button down on the side of the TV and keep it held down. At the same time press the ‘on button’ on your remote control until the green light appears. DO NOT take your finger off the TV button until about 10 seconds. Release the TV button and hope for the best! It worked for us . Good luck.
Score 2
1 Comment:
Many thanks,worked a treat
by
Add a comment
Add your answer
Randy Weaver will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 48
Past 30 Days: 185
All Time: 190,998
