Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
trackpad button stuck
Hi,
My trackpad button is stuck down. Is this fixable, or must it be replaced? Can I try to pry it up, or will I risk breaking it? Should I take the topcase off and investigate first?
Thanks...
Score -1
Add a comment
1 Answer
Most Helpful Answer
Hello!
The danger with prying it up is that you can create small burrs in the plastic that further rub and hinder trackpad button use. I would investigate by removing the upper case, as you mentioned (especially because the removal is an easy one)!
I hope this helps!
Score 1
Add a comment
Add your answer
twinn will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 3,281
