What upgrades can I do to this G 8 desktop?
Have a 0ld G 8 G86503FYUPZ. Looking into filling the memory to 8 gigs. Is there a new updated logic board and can this unit be made wi fi?
It appears this is your machine:
Apple Mac Pro "Eight Core" 3.0 (2,1) Specs
Identifiers: Mac Pro - BTO/CTO - MacPro2,1 - A1186 - 2138
http://www.everymac.com/systems/apple/ma...
Standard RAM: 1 GB Maximum RAM: 32 GB*
RAM Type: PC5300 DDR2 ECC Min. RAM Speed: 667 MHz
Details: Uses "667 MHz DDR2 ECC fully-buffered DIMM (FB-DIMM) memory" with a heatsink design that is a bit different than generic FB-DIMMs and has "up to [a] 256-bit wide memory architecture".
Details: 1.0 GB of RAM installed as two 512 MB modules. 6 slots free. RAM must be installed in pairs, and for "best acoustic performance" contain an "Apple-approved heat sink".
*Apple officially supports a maximum of 16 GB of RAM but third-parties have been able to upgrade the system to 32 GB of RAM using eight 4 GB memory modules.
Standard Hard Drive: 250 GB (7200 RPM) Int. HD Interface: Serial ATA (3 Gb/s)
Please tell us if you have done any upgrades, added a hard drive or any PCI cards, what your budget is and what you main usage is and what you want to do with it.
To the best of my knowledge neither I or my Daughter can not recall doing any upgrades. At this time was not considering a budget until I can see what can be done. One thing for sure is to fill the memory to 8 gig after that any suggestion
I go with at least another hard drive and put a system on it so you can boot from either drive and repair one from the other. Maybe a SSHD drive to use as the main. When doing the RAM, keep it in pairs and add 2 4GB sticks.
Ok that sounds good and I under stand the memory but where is a good site to buy memory. Can this unit be upgraded to handle El Capitan or does the mother board need to be upgraded.
Pre-Installed MacOS: X 10.4.9 (8P4037) Maximum MacOS: X 10.7.5*
Be careful when buying RAM for this machine as it can be very high dollar. Here's a couple of links for reasonably prices used RAM: http://www.ebay.com/itm/Kingston-16GB-4x...
http://www.ebay.com/itm/4GB-KIT-2X2GB-DD...
Consider going to a SSHD hard drive for a speed and storage boost, the 2 TB drive can be had for about $8 more tan the 1 TB: Seagate Hybrid Drive ST1000DX001 1TB MLC/8GB 64MB Cache SATA 6.0Gb/s NCQ
Or even a 4TB drive such as this: 4 TB 3.5" Hard Drive Desktop SSHD
Thanks now to find the time to upgrade with grand kids and three busted finger and all the honey dew lists
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 90
