Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
Will not power on after replacing digitizer and battery
I replaced a digitizer and battery in an iphone 4s and after the repair the device would not power on. After further inspection i found that the power button ribbon had torn so I replaced it with a new ribbon assembly. I still have the same problem. It will not power on but when I plug it into the charger the apple symbol comes on for about 10 seconds and then goes off for about 10 seconds and then comes back on. I had another known good iphone 4s and swapped parts over to it and they work in that phone but not the one I am working on. Has anyone else run into this situation?
Score -1
1 Comment:
Sounds like a dodgy battery
by
Add a comment
1 Answer
make sure your battries ok. swape your battries from good 4s. If still same. replace all connector 4s and plug-in againt.
Add a comment
Add your answer
OmahaWest will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 39
