2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
Logicboard replacement; new thermal grease/compound?
Hello fellow diy-people,
Is it smart/necessary to put some extra/new thermal compound between the heat-sink and the cpu/chipset??
thanks in advance!
Guido
Score 1
2 Comments
Well, after investigating the situation inside the MBP, It was necessary to remove the old grease because it was kind become solid-ish....so removed the old compound with special cleaner, then added new "Artic silver 5" and everything runs as new! Did two laptops, and this step is necessary. Old stuff doesn't make a good connection with the heat-sink. Thanks for the comments!
Guido
by
Thanks for accepting the answer, glad I could help.
by
Add a comment
1 Answer
Chosen Solution
I wouldn't do it unless you're running hot.
Here's a guide on doing it: How to Apply Thermal Paste
Score 1
1 Comment:
Agreed +
by
Add a comment
Add your answer
iFatamorgana will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,537
