Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Glass only replacment!? -iPhone 6
Hello everyone!!
I'm a pretty techie person and recently someone punched my iphone and cracked the screen!!!! I'm over joyed about this!!!(He punched it from behind btw, idk how but it cracked). Anyways, the lcd and digitizer are fine, but I hate having cracked glass. i know that the glue from the glass to the frame is very difficult and super strong in the 6's HOWEVER, the screen I have is after market and pretty cheap and the adhesive that holds the glass to the frame is super weak and is already starting to fall off. I could easily get the glass and lcd away from the frame of the screen. My question is, once the frame is off (which will be VERY easy) could I easily use a molybdenum wire to get the lcd off? And if I could, would I be able to use some loca glue and a glass replacing mold and stick a new one on there and then super glue it to the frame??
Thanks!!!
Ben
Add a comment
Most Helpful Answer
The biggest issue, apart from the iPhone 6 being almost impossible to without certain equipment, is that the frame is very hard to glue to the glass. It is VERY hard to get a correctly sized frame, and you CANNOT use super glue as it's strength deteriorates after a few weeks. You have to use high strength hot glue frames which can sometimes be found online, or Cold Press Glue that apple uses to bond screens.
Score 2
Add a comment
It's almost impossible. The glass and the LCD is designed to be together. In my view, if you try so, you might damage the LCD.
Add a comment
Add your answer
Ben Wilson will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 10,065
