Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
poor gps after screen and battery replacement
iphone 5, replaced cracked screen and battery, since then very poor gps tracking in maps and google maps . looks like it is only using cell triangulation . is there a way to actually see signal strength ( app?) possible common issues/ start points to look for ?
wifi signal is good and cellular is good as well
Add a comment
1 Answer
Chosen Solution
I would guess try resetting your cellular settings, or just do a reset. If other things are working it almost doesn't sound like there's a hardware issue
Score 1
2 Comments:
well considering it began immediately after replacing the screen and battery, and was working 100% before, it seems to be far more likely I've possibly dislodged or damaged the cable or connection than a software issue .
by
Try disconnecting and reconnecting your battery, then connecting to wifi. Sounds like you just did that. But, it also sounds like that's where this is coming from, if wifi and cellular are working just fine
by
Add a comment
Add your answer
Mazdanoob will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 2,447
