The Nexus 6 is an Android phone developed by Google and Motorola released in 2014 with a 6-inch display.
68 Questions View all
Device will not power on after battery replacement
I purchased a replacement battery from ifixit, and followed the teardown. All went smoothly, phone is reassembled now. When I plug in the micro USB, the screen lights up with the charging indicator.
When I press the power button, the phone does not power up. I was careful when prying off the back cover, avoiding the ribbon for the power/volume buttons.
Any thoughts?
Score -1
2 Comments
Hi, Is the battery sufficiently charged? Hopefully your charger has enough output to run the phone and charge a low battery (if that is the problem)
by
Hi, thank you for the response. The charge indicator shows beyond 75%. The phone does not power up with USB plugged in or unplugged.
by
Add a comment
1 Answer
Chosen Solution
did you reconnect the power button?
Score 2
2 Comments:
That's the power of community! :) I didn't realize the tolerance of this connector when I was reassembling. For those taking off the mid plane, perhaps it is best to remove the black plastic cover on this connector instead of just relying on hope that the connector is aligned correctly with the socket beneath. Thank you!
by
np dude, i have that phone and its the first thing i thought of lol
by
Add a comment
Add your answer
kc7eph will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 368
