The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
Why my 2DS does not open?
I have a 2DS and when I power it on the blue light turns on but the screen still remains black. After some seconds it makes a wierd noise and turns off completely. My brother says that it has been exposed to water . Any ideas on how to fix it?
Add a comment
Chosen Solution
This is a complete guide for teardown and troubleshooting and can guide you through your fix
Nintendo 2DS
Hope this helps
Score 2
Add a comment
Put in rice for a day
Score -2
7 Comments:
Rice is a food not a tool
by
But if it gets wet it will soak up all the water
by
@Cozy Rozema, Rice is absolutely useless. It will not remove all humidity, it will not prevent corrosion, it will not remove liquid between components and it will not prevent short circuits. Using Rice as a desiccant is the equivalent of doing nothing.
by
You're Both Right - Rice is a fine opening move for consumer water removal, but OldTurkey has a point, it's not going to solve your problems; disassembly will be required.
by
@alinorne Kevin - Rice as a desiccant is an old wives tale. Even if you boil it, it only soaks up 2X. Unboiled all it does is make a mess. Your voracity as an answer giver is at stake here, do the research!
by
Show 2 more comments
Add a comment
Add your answer
John Hatzis will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 29
All Time: 400
