iPhone 5 no power
Hi everyone, I have an iphone 5 which i tried to do a DIY housing replace i did all the correct steps. when i removed the screen the first thing i did is disconnected the battery cable from the motherboard before touching the other components so i cant of done something really bad to it .
I have connected everything together tried powering it nothing no sound/vibration even when i plug it to the wall charger or PC (PC dont detect anything either. I did disassemble everything and assemble it back together just to check if i missed anything out. but no luck.
Thanks you.
Are you sure you connected the battery and lightning cable jack cables correctly?
by Jake
Thank you Jake for your comment and yes I have connected everything correctly, not sure whats the problem?
by moheenmohammed12
