Repair information and guides for the fifth generation of iPhone. Model: A1387
No Ringer; Doesn't Turn off
I need help please! :(
My phone got wet... Didn't soak into a body of water though. water got spilled on it.
Now there's no ringer. When I press the + and - button, no ringer bars appear. Sometimes it works then after a few minutes, it wont work again.
Also, my phone no longer turns off. It just restarts even though I slide it off. Please please help. Thank you!
Score -1
Add a comment
1 Answer
Most likely need new charging port with flex cable. First, clean the iPhone charging port very well with clean toothbrush and isopropyll alcohol, clean it very well. If still problem, then replace the charging port with flex cable, a single part which includes the lower mic and the connector to the home button flex cable.
1 Comment:
My phone's okay now! First, I tried cleaning the charging port and it worked for sometime; ringer bars appeared but after a few minutes it disappeared again. Then I tried putting it on rice grains and waited for 10 hours (my phone's still on cause it wont shut down) and now it's okay. Thank you!
by
Add a comment
Add your answer
Anna will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 51
