Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 Questions View all
Why can't I boot my iMac G5 2Ghz Intel Core 2 Duo?
After using it for about 14 months, I have suddenly not been able to boot up my iMac G5 2Ghz Intel Core 2 Duo. It powers up but I only get a grey screen that eventually changes to the “Flashing-?-Folder”.
Depressing the option key at startup produces a depiction of a hard drive but clicking on the arrow beneath it only freezes the cursor – eventually changing again to the “Flashing-?-Folder”.
I’ve reset the PRAM several times to no avail. Ran the hardware test, short & long, produced “No trouble found”.
Tried “Disk Utility’s First Aid” which produced “Failed” “Stopped verifying permission on Macintosh HD” because “No Valid Packages”.
Is there any other option to get access?
If not, could I remove the 160 GB HD & install one of a higher capacity?
Could I then find a way to access the files on the 160 GB HD by making the removed HD an External Drive in its own case?
Any other ideas?
Score -1
Add a comment
1 Answer
Chosen Solution
Hi, It sounds as though your hard drive is bad. Please select your computer from the list and then select hard drive replacement for replacement instructions. Yes you can install a higher capacity drive. As to recovering your data I would try but don't know how successful you will be. One other thing you might try is reinstalling your OS. Good luck.
iMac G5
Score 1
1 Comment:
+ agreed on the bad hard drive. I edited the machine to an Intel instead of a G5. If you have doubts as to your exact machine, please look on the bottom of the stand. Repair instructions are very, very different for the G5 vs the Intel machine.
by
Add a comment
Add your answer
Roderick Black will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,350
