1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
142 Questions View all
Question Closed
Sound does not work
I have the same problem as this one..The sound works intermittently.. I went to preferences/sound and it would not let me highlight anything in the output or input section and it displays "no output/input device found". The sound was working fine.. then it does not. I do not change anything, I am not that clever. Could it be the cord between the computer and the monitor?
Add a comment
1 Answer
Chosen Solution
If you have the same issue as that one, then you either need a new logic board or can use USB-equipped speakers to bypass the issues. The USB speakers would probably be the cheaper alternative. You can start looking for USB speakers that are compatible with a mac (double check!) HERE.
Add a comment
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 985
