Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 will not charge.
Hey Guys,
Just had a quick question regarding charging on an Iphone 6. A customer brought in an Iphone 6 that would not charge, we tried a few different charging ports and the device would still not charge. When powered off, charging cable can be plugged into the phone and will boot. When plugged in the device displays a message saying please use apple charger, but the charger we were using is a Apple charger. She was using an off brand charger at one point. Anybody have any experience with this issue? Thank you in advance!
Score 1
Add a comment
Chosen Solution
"She was using an off brand charger"
There's your issue right there.
She has damaged the U2 IC chip, the message asking you to use a genuine charger (even if you are) is one symptom of it, more severe symptoms are:
- Overheating
- Fast battery drain (even in airplane mode)
- Fake charging (shows charging symbol, but percentage usually goes down)
- Phone charges when on, but if left to die, will not charge, but is able to come back on with a charged battery
The only fix for this is to replace the U2 IC chip.
Score 3
1 Comment:
I figured it would be something on the board, we have tried everything else, thank you for the answer! I appreciate it.
by
Add a comment
Have you tried another battery? I have seen iPhone 6 batteries dying at a quicker rate than any other iPhone model.
2 Comments:
I did try a different battery, it was able to boot up, but it still would not charge. :( Thank you for the suggestion!
by
You've already replace the charge port, so that's the only other troubleshooting step I know. Im hoping nothing on the board is bad. I have seen off brand chargers cause problems. I've seen them destroy phones, although I have seen people use them without any issues as well. Can you try a different cable and power brick just to test? Im grasping at straws at this point.
by
Add a comment
Hi,you can take a moment to read this article How To Fix Slow Or Unable To Charge Problems May it can help you.
Add a comment
Add your answer
leevancleef will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 12
All Time: 5,411
