Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 Bent housing no signal/service
iPhone 6 housing bent and motherboard bent towards the bottom of the phone and motherboard, everything works except that it will not get any signal/ cell service. It works on wifi, but on the top where it usually says the carrier it keeps saying searching, even after I pull the SIM card out it keeps saying searching. No bents anywhere near the SIM card reader. Tried a different sim tray, network reset, opened the phone and checked all the connectors and components. I haven't done a restore on the phone. I believe it mind be hardware related because it happened when the phone got badly bent. Any suggestions on things to try or how I can fix the problem. Thank you
Score 3
Add a comment
Most Helpful Answer
Reflow the entire cellular section, reball the cellular chips if necessary.
Score 2
Add a comment
What does reflow and reball mean?
Score 1
1 Comment:
Reballing is a method of soldering which requires balls to be placed underneath the chip. The process requires a de-solder and a fully equipped solder station. You have to desolder the cellular chip with a de-solder station and resolder it. Trust me it's a nightmare. You're gonna want to take it to a specialist or get a new phone.
by
Add a comment
Add your answer
Dewells will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,963
