Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
MacBook Pro water damage, OS X running really slow?
I have a MacBook Pro 2009 Unibody model that was water damaged. I opened up the laptop, took everything out and cleaned it with some rubbing alcohol. After doing that, the laptop was finally able to turn on. However, when it boots into OS X, it is incredibly slow and laggy and the fan is constantly running at top speed. I understand that perhaps a sensor was damaged or some other small component on the board was fried. Now the strange part is that although the MacBook does not run OS X as smoothly as it should, it runs Windows 7 and Ubunto perfectly fine.
Score -1
1 Comment
How much RAM does it see? Check you start up items in System Preferences > Users
by
Add a comment
1 Answer
Most Helpful Answer
I would start off by resetting the SMC to see if that clears things. Follow this Apple T/N: Resetting the System Management Controller (SMC) on your Mac.
The next thing I would do here is download this app: TG Pro It will allow you to see the sensors and fans. Take a screenshot of what it shows and paste it into your question so we can see it as well.
Score 2
Add a comment
Add your answer
James Entine will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 702
